Nego sad sam proveravao koji sve tipovi fajlova mogu da se otvore u EMC2. Sem vec pomenutog NGC, mogu se otvoriti PNG, GIF i JPG (stvarno ne znam zasto moze da otvara slike) i PY (Python Script) za sve oni koji rucno kuckaju kod
Zaboravio sam jos da pomenem da se prilikom snimanja toolpathova u ArtCAM-u mora izabrati odgovarajuci postprocesor. U samom ArtCAM-u vec ima mali milion postprocesora za razne marke i modele CNC masina, ali posto moje (naravno) nema na spisku morao sam da ga dodam (dobio sam ga sa masinom). Nisam bas siguran cemu tacno sluzi taj postprocesor (najverovatnije se u njemu nalaze parametri konkretne masine), ekstenzija mu je CON i male je velicine. U kodu sam stavio sta se u njemu nalazi.
Code: Select all
DESCRIPTION = "Micro (mm) (*.ngc)"
FILE_EXTENSION = "ngc"
UNITS = MM
; Cariage return - line feed at end of each line
END_OF_LINE = "[13][10]"
; Block numbering
LINE_NUM_START = 0
LINE_NUM_INCREMENT = 10
LINE_NUM_MAXIMUM = 999999
; Set up default formating for variables
; Line numbering
FORMAT = [N|@|N|1.0]
; Spindle Speed
FORMAT = [S|@|S|1.0]
; Feed Rate
FORMAT = [F|#|F|1.1]
; Tool moves in x,y and z
FORMAT = [X|#|X|1.3]
FORMAT = [Y|#|Y|1.3]
FORMAT = [Z|#|Z|1.3]
; Arc Centre Cordinates
FORMAT = [I|@|I|1.3]
FORMAT = [J|@|J|1.3]
; Home tool positions
FORMAT = [XH|@|X|1.3]
FORMAT = [YH|@|Y|1.3]
FORMAT = [ZH|@|Z|1.3]
; Set up program header
START = "T1M6"
START = "G17"
START = "G0[ZH]"
START = "G0[XH][YH][S]M3"
START = "G04 P10"
; Program moves
RAPID_RATE_MOVE = "G0[X][Y][Z]"
FIRST_FEED_RATE_MOVE = "G1[X][Y][Z][F]"
FEED_RATE_MOVE = "[X][Y][Z]"
FIRST_CW_ARC_MOVE = "G2[X][Y][i][J][F]"
CW_ARC_MOVE = "G2[X][Y][i][J]"
FIRST_CCW_ARC_MOVE = "G3[X][Y][i][J][F]"
CCW_ARC_MOVE = "G3[X][Y][i][J]"
; End of file
END = "G0[ZH]"
END = "G0[XH][YH]"
END = "M30"
