Thiknes dram sander
E pa tako ti i treba kad si ucio, a nisi lepo priucen ko nas dvojica :)
Sa cpanela mog (a bese i tvog) provajdera:
HotLink protection prevents other websites from directly linking to files (as specified below) on your website. Other sites will still be able to link to any file type that you don't specify below (ie. html files). An example of hotlinking would be using a <img> tag to display an image from your site from somewhere else on the net. The end result is that the other site is stealing your bandwidth. You should ensure that all sites that you wish to allow direct links from are in the list below. This system attempts add all sites it knows you own to the list, however you may need to add others.
So nije problem, al nije lepo. Ma ustvari najvise je problem sto je veza ka njima spora :)
Nisam bio lenj, pa sam upravo konsultovao wikipediju :)
http://en.wikipedia.org/wiki/Inline_linking
Ne moraš da ideš tamo, preneću početak teksta, čisto da stavimo taku na diskusiju:
Inline linking (also known as hotlinking, leeching, piggy-backing, direct linking, offsite image grabs and bandwidth theft) is the use of a linked object, often an image, from one site into a web page belonging to a second site. The second site is said to have an inline link to the site where the object is located.
branimir
Post by branimir »
Da li je ovo forum za stolare ili kompjutere
Za stolare koji koriste kompjutere :)
Salim se stvarno smo malo preterali.
Gospodo dali se na onaj valjak prije šmirgl papira još nešto ljepi i sa kojim bi se ljepilom to sve trebalo naljepiti?
branimir wrote:Da li je ovo forum za stolare ili kompjutere
Ajde i ja da se odjavim sa ovog off-topica, samo da znaš, ja ne bih ove stvari razdvajao ;) (obavezno pogledati!)
http://student.dei.uc.pt/~octavio/caixa/index_en.htm
Oni su koristili cicak traku. Ja je ovde nigde nisam nasao u tako velikim dimenzijama. Ona je obicno samolepljiva, ali ako nije, onda se lepi nekim neoprenskim lepkom (tigar, sintelan, neostik). Isti lepak se koristi i ako nema cicak trake pa se smirgla lepi direktno na valjak.
Ok čičak traku sam jedino našao za odjevne predmete znači širine oko centimetar odprilike to se može namotati i ona se sama zaljepi i drži vraški ali dal ima šmirgle u metraži znači na metre da se može zaljepiti na čičak sa onom mucom-sintetikom,to nisam nigdje vidio?
Ovde u Srbiji koliko znam je gotovo nemoguce naci na metar smirglu "sa postavom".
Za ove nase terene pre bih isao na neki sistem kao sto je na hoblericama za parket. Znaci ne lepi se traka nego ima zleb na valjku u kome se zategne. Ne znam kako se to tacno izvodi. Googlacu malo veceras, mozda nesto iskoci.
Rendisha
Post by Rendisha »
Moze se spiralno motati traka smirgle pa na krajevima pricvrstiti nekim prstenovima (u slucaju da se ne koristi cela sirina valjka). Tada je bolje imati gumirani valjak.
Bojan
Administrator
Administrator
Post by Bojan »
U shopnotes-u 86 (fala, Metabo) se čitava traka ne lepi na bubanj, već se priteže konusnim parčadima bubnja na isti, tako da ne treba čičak traka, a i šmirgla se lako zameni, odvrnu se dva šrafa i stavi druga šmirgla.
Evo kako to izgleda:
nikola145
Post by nikola145 »
Imam slicnu masinu koji bih da prodam.
Valjak je sa donje strane sirine oko 60 cm precnika oko 25 cm. Ima jos jedan valjak odozgo koji pritiska samo svojom tezinom. Smirgla se priteze metalnim klinom sa srafovima, valjak je drveni, motor oko 2 kw, radna ploca 1x1 metar otprilike.
Dao bih je jeftino (300 E) ako nekoga zanima...
budak
Re: Thiknes dram sander
Post by budak »
Da li sada ima negde da se kupi čičak platno dimezije recimo 30 x 30
Skoro sam trazio, ima na Aliju
Recimo:
https://www.aliexpress.com/item/1005005 ... in_prod%3A
