Obrada drveta a ne prstiju
digger
Post by digger »
Fotografije su me inspirisale da ih prosledim i na ovaj forum. Na zalost, nesrece nemaju granica. Preuzeto za foruma: http://www.routerforums.com
Direktni link do posta: http://www.routerforums.com/shop-safety ... pened.html
Na postu ima jos fotografija a tekst prilazem. Nadam se da nije problem sto sam iskopirao tekst na ovaj forum. Mislim da svima moze da koristi.
I was doing a flush trim cut (.75” X 1.25” .5” Shaft flush trim bit) using ¼ inch hard board template. By the way, number 4 out of 4, so it was not the first one. The pine board was about 3 feet long with a 10 inch template at the right end of it. I was a couple inches into the cut, guiding the board with my right hand when all of a sudden the board flew to the right and the fingers of my left hand were in the router bit. The rest is history, including the ends of 2 fingers.
It’s been a week now and I think that I figured out what might have happened.
1. I think that the board somehow road up off of the bearing and then dug-in big time and fast
2. I think that the fingers of my left hand may not have been behind the board, but resting on top of it holding it down.
3. The board launched from left to right like a bullet, so fast that my left hand did not react, but instead went with the board to the bit. Just like a kick back on a table saw.
Does this sound like what may have happened?
Milos
Marko Enter
Post by Marko Enter »
Da, frezer je djavo, otkine deo kao nista, tako je mojoj babi dok je bila zena jos , u jednoj firmi gde je radila otkinuo komad srednjeg prsta, kaze nije uopste osetila samo videla krv, i pravac za bolnicu, 1 sekunda nepaznje i gotovo, sta kad uporedis ljudsko meso i drvo to je maltene 100 puta meksi materijal
pozdrav i veliki oprez sa masinama
Bez znanja nema zanata :)
gilee
Post by gilee »
imao sam,na zalost,priliku da se moji prsti susretnu sa abrihterom i cirkularom.doduse oba puta uz minimalnu povredu.mogu vam reci da stvarno ne boli.imam sve prste na rukama a palac i kaziprst leve ruke sa manji oziljkom koji su gotovo neprimetni.oba puta sam posle previjanja,samostalnog,nastavio sa radom.poslednja povreda se desila pre nekih mesec dana(na cirkularu)
nije sramota pitati,sramota je praviti se pametan
digger
Post by digger »
gilee wrote:imao sam,na zalost,priliku da se moji prsti susretnu sa abrihterom i cirkularom.doduse oba puta uz minimalnu povredu.mogu vam reci da stvarno ne boli.imam sve prste na rukama a palac i kaziprst leve ruke sa manji oziljkom koji su gotovo neprimetni.oba puta sam posle previjanja,samostalnog,nastavio sa radom.poslednja povreda se desila pre nekih mesec dana(na cirkularu)
gille,
ti si za sada zarezivac olovaka. da na kraju ne bude zarezivac prstiju. :)
petras
Post by petras »
Sem opaski trebalo bi dati i konkretne savete jer u stolariji nema bezopasnih alata niti masina.Podrazumeva se koncentracija i trezvenost (u svakom smislu).Na arbrihter se nikada ne pusta komad a da vodjica (firung) nije na svom mestu.Dodajmo svaki dan ovde po jedno "pravilo" bice korisno za sve nas koji volimo ovaj zanat.
kam taj rock n roll
NEX
Post by NEX »
Svaka masina je opasna na svoj nacin.Pa cak i disk sa nalepljenom smirglom,naizgled bezazlen a osmirgla prst i nokat zacas.
Stoga oprez!
Pored toga sto radnik mora biti koncentrisan na rad bar 95 %,mislim da je cesti uzrok povreda i brzi rad.Zato polako ,u glavi napravi koncepciju rada,pa pazljivo korak po korak pa do finala.Stalozeno,samouvereno,sigurno,bezbedno i sa voljom i elanom,korak po korak i eto uspeha.
Mislim da svi koji su radili na masinama i u radionici ,podrzace ovo razmisljanje.
Procitavsi Petrasovu poruku ,sa kojom se slazem,morao sam i ja nesto dopuniti.
digger
Post by digger »
Da budem iskren, ne znam sta bih trebao da uradim da budem sigurniji kada na glodalici obradjujem nesto kao sto je i ovaj nesretnik. Mozda drzati prste sa druge strane obratka (ne sa iste gde je i noz). Kada treba obraditi manje komade, onda se oni stavljaju u stegu i tako obradjuju, ali ako je veliki komad u pitanju, stvano ne znam.
Milos
Koristis one paknice. Pa ako nesto i zvekne, odrezo je deo paknice, a ne deo tvog prstica.
NEX
Post by NEX »
Pa ruke sto dalje od glodala.Ako ono ne pravi vibracije sigurnost je veca.I pazi na zadnji komad u seriji na frezeru , on je uvek najnezgodniji jer je paznja najmanja.
Aliriza Hasku
Post by Aliriza Hasku »
Ne znam, nesreca je nesreca, ali obicno se takvi slucajevi dogadjaju sa velikim komadima a ne malim, ipak kazem ne znam, jer muka je kada sa iskustvom od 17 godina pa ti se dogodi takva nesreca a za pocetnike nije ni cudo, to kazem za mene jer ja sam to doziveo pre dve godine, sta ces mu to je unutar rada, u tim slucajevima sekunda je velika a ne minuta. Ipak zelim svim stolarima SRECU i da ne dozive nesto ne daj boze....
Opasni su koliko mali toliko i veliki komadi.A najopasnija je nepaznja.
ArtCool
Post by ArtCool »
Kada sam video slike sto se nisam prevrnuo sa stolice, sunce mu *ebem.:o
A manja povreda.
Pih imam slab stomak.:(
Bogu fala da kucnem u drvo (kuc-kuc-kuc) nikada se nisam povredio.:cool:
Sve sto reze je opasno tako da je najbolje raditi odmoran,bez rukava,dobra rasveta,nepusiti vasljive cigarcine :mad: posebno dok se radi na strugu i NIKADA se ne opustati dokle god se motor vrti (brusilice,cirkulari,strugovi itd).
Masina je napravljena da nosi a ne da mazi.
Pozdrav svima kojima su svi prsti na broju a i onima kojima nisu (takvih je više medju stolarima)
Moj koristan savjet je da nikad dok nešto obradjujete na frezeru, ako vam se učini da ste slabo obradili, ne vraćate unazad već da provučete do kraja elemenat pa tek onda ako treba provučete još jednom. To je važno jer su pri vraćanju unazad ruke opuštenije i kad nož dohvati neobradjeni dio teško je zadržati komad a još ako su prsti na kraju komada, naježim se kad pomislim... Samo oprezno bez opuštanje jer mašine nemaju dušu!!!
Sasa wrote:Samo oprezno bez opuštanje jer mašine nemaju dušu!!!
Imaju imaju dušu samo nekada ne onu koju bismo htjeli da je prisutna,već onu koja radi ovakve stvari od nas ili nedaj Bog od Vas.
miki_bgd
Post by miki_bgd »
Stara tema, ali mislim da je vredi podici:
Po meni je ovo:
http://www.microjig.com/products/grr-ripper/ idealna stvarcica za amatere a profesionalce. Sa ovim su povrede svedene na minimum.
https://www.youtube.com/watch?v=MlYKQbQIpnc
